My temp. guage isn't working and I replaced the temp. sending unit on the thermostat and it still doesn't work what else could it be? there is a sending unit on the bottom of the radiator is that it or could it cause the guage to not read?
I have emergency flashers, (so all my amber bulbs appear to be OK) but, turn signals won't flash, reverse lights won't work, temp guage and gas guage are dead... Any Ideas, all the bulbs and fuses are good. what else is there?
You could get a multi meter, and check for continuity from the switch at the moter, to the plug for the guages. Of course you have to know which slot is for the temp guage.
Mine had a problem with the temp guage, turned out there was a break in the wiring for the temp sender. It happened to be right at the sender, so I only had to replace a short peice of wire at the sender......where leif described.
