Tri 4-LINK SET UP
gkellison46@gmail.com's avatar
Tri 4-LINK SET UP
truck action's avatar
truck action
I know this is on many a form, but I have got a lot of differant asnwers. So in setting up a tri 4-link, on a 88 Toy. What angle on upper bars? Here's some photo's of what I'Mm doing, the lower bar needs to be shortened 3 1/4'', so in the same plain as the upper. with this lay out the upper bars are at 40 degrees to the axle. Both upper & lower bars are parallel to the ground & each other. Would like to get the upper bar a little lower,will have to cut the brackets ,or change the angle( bring further down the axle from the pumpkin).
Sorry for the long story, really need this right! Any & all help!://minitruckzone.tenmagazines.com/gallery/RestNot/93831.://minitruckzone.tenmagazines.com/gallery/RestNot/93833.jpg
johnny5's avatar
johnny5
this is how i did mine
truck action
Are the upper & lower bars parallel? Looks like the upper bars angales down, & what is the angle of the upper bars to the frame? I read that should be between 38 & 40 degrees. I know the lowers are to be paralle at ride height, not sure on the upper.Also your pivoit point at the front , both upper & lower should be on the same plain, in line with one in other. That's what I,ve read!
johnny5's avatar
johnny5
at ride hieght they are parallel and level with each other, never had a problem
truck action
Yes on both uppers & lowers parallel at ride height best angle for uppers 45 degrees. And the front piovit point should be in line upper & lower.
Still want the upper mounting point at the frame lower,so not to hit the bed bottom! Any photo's . At ride height my frame is 5'' at the rear, 4 1/2'' at front.
johnny5's avatar
johnny5
no pics yet not done with the b'd lol
