front bump stops
insane@hackermil.com's avatar
front bump stops
vegasyota94's avatar
vegasyota94
well i see two bump stops on each side.. one is a rectangle on the lower arm... and the other looks like a point kinda thing... if i remove these, will this lower the front at all? i already have the upper arms ball joints flipped, but not the lower.... so if i remove these bump stops will i get any drop? if so, will the ride be shittier then just have the torsions un wound??
twisted minis's avatar
twisted minis
Dude, why did you just flip the upper? You didn't make your truck any lower, you just changed the angle of your upper arm. You need to flip the lower, and you'll get about 3/4" drop. The bump stop on the arm might limit you from going lower. The other ones stock your arms from dropping down too far.
vegasyota94
ok i will do the lower... im just worried about doing the lower with the stock bolts.. and im broke right now to get the bolts u told me to... so i should do it anyways huh? lol
twisted minis
I'd wait and get the Grade 8 bolts. I think yours are pressed studs. They won't work if you turn them over. So just wait until youy can by the bolts. It's safer that way.
vegasyota94
ok will do.. im too drunk rtight now anyways
