Fuel Cell or stock tank?
sitnlow4life
Guys I cant decide what to do here.
I know the fuel cell is the best bet but I dont want to loose functionally of my fuel gauge.
Any suggestions?
no1lowr's avatar
no1lowr
why would you with a fuel cell, mine just says 1/2 tank when its full
twisted minis's avatar
twisted minis
Keep the stock tank. Theres nothing wrong with them.
chuck6899
if you are planning cleaning your stock tank of old gas, here's how to do it. drain your tank( duh){ my has a drain plug}, pressure wash it, let dry ( 24hrs sounds good) there is some stuff you can put in your gas to get rid of water in the tank, use that the first tank full.
sitnlow4life
Cool
I plan on keeping it then.
what can I do about the feed line the 2 fitting on it are sooo rusty they feel like they are gonna break when I try to losen them.
I soaked them with pb blaster still no good.
Any ideas?
If I break the top one I will have to buy a new pump for the tank.
If I break the bottom one its hard line all the way to the front.
Thanks again
U
uselesstoy
if u bust them u can braise a piece of brake line in place or compression fitting if there is enough left on the top of the tank. thats what i had to do because my truck saw a couple of salty winters. but then i scored a mint sending unit at a junk yard.
mexicant
i have a jas fuel cell and i use the stock sending unit and my gas gauge still works , i like it better that the factory one especially when i polish it up !
sitnlow4life
Dude thats awsome
What fuel cell is it?
What mods did you have to make to get it to work with the stock sending unit?
Any pics?
Thanks alot
sitnlow4life
Yo man you there?
blockhead brian's avatar
blockhead brian
I went to clean out my stock tank and it was totally rusted inside. So I decided to order an RCI fuel cell. Should be here soon and I hope it's easy to hook up. I ordered one with a sending unit.
