Yota Lowering \  Center support bearing flip?
Yota Lowering Yota Suspension Yota Tech
views 917
replies 3
kdcgrohl   +1y
what do you guys do with your carrier bearing/drive shaft center support bearing when bagging. looks like it hangs too low to be safe when layed out. just flip it above the bracket or flip + shims?
cable   +1y
you talking about the crossmember that's at the back of the cab?if so I cut that shit out.
ryann   +1y
yea i chopped mine out and lifted it like 70mm
(Aussie hilux BTW)
lowtaco114   +1y
i believe ur talking about the driveshaft carrier crossmember. I cut mine, flipped it and welded it back in. all you have to do in make sure you cut it so it does change the position on the carrier in relation to were is was.
