Yota Lowering \  Valve set ups
Valve set ups
Yota Lowering Yota Suspension Yota Tech
views 896
replies 5
truck action   +1y
Still trying to get some photo's of valve set ups. Want a manifold set up close to the bags front & rear,will be using check valves in line.
Any photos will be a great help.
kdcgrohl   +1y
put em on the tank, you'll be happy. no wires running all over the place, everything in one location, good response time...
truck action   +1y
Was going to do that( got nickle plated Asco valves), but the check valves will do little good that far away from the bags!
kdcgrohl   +1y
only falure point would be the lines, and if properly installed, how many lines have you seen bust. now compare that to compresser leaks, leaderhose swivels breaking, or temporary valve failure due to debris. puttin em on the tank takes out all the failure points except the bag(cant fix that), bag fittings(cant fix those either). and the lines. basically, i just hate finding valves in random places around the truck. also, putting the valves near the bag adds another leak point in your fitting setup, but whatever i'm rambling now...
sitnlow4life   +1y
Hey what kinda tanks are they in the first pic?
kdcgrohl   +1y
slim and skinny 5 gal
suicidedoors
