Chevy/GMC Trucks \  Post here if your s10 is running BYC arms..
views 97
replies 0
following 1
AVTekk   +1y
Im working with Mike over at BYC to straighten out a few problems thats Ive seen with his arms so Id like you guys to post whether or not youve had these or any other problems. Heres the two big things for me right now:
- The lower control arm is too short, causing lots of positive camber and requires the upper to be loaded up with alignment shims.
- The bags Im running have 2 bolt holes on the bottom and the one hole falls right over the front tube of the lower control arm so they cant be bolted in.
If you have BYC arms you should know what Im talking about, the bag sits offset towards the front of the plate, and itll work fine for a bag with one bolt but 2 bolts will never make it. Im surprised no one else has had this problem tho..Ive seen guys loading up the top arm with shims tho, and right now I have 3/4" of shims on one arm and I get 0
