94dakota
I was looking though the manual for my truck and noticed the 4wd and 2wd seafspring setup is different. On a 2wd the axle is above the spring and the shakle is mounted with the spring on the bottom. On the 4wd the axle is below the leaf with the shakle mounted the opposite way. I think the hanger is mounted higher on the frame on a 4wd also. Do you hink if you took shakle and hangers off the 4wd would it lower a 2wd and the 2wd stuff lift the 4wd???? I think it would it looks like it would work by the pics in the manual
