4 linkin a 92 chevy
1 following
4 linkin a 92 chevy
just2low4urho
Ok im in the process of putting a bigger notch in my truck,and at the same time im doing a 4 link. I just had a couple of questions about it seeing as i've never done a 4 link before. Im using 2in square tubing with the round bushings at each end for the the parallel bag bars. Now for the the inner two bars i was going to order them off of suicide doors, the ones that are adjustable on one end and welded up on the other. Do these need to be set and a certain angle? If so like whats the degree? Also im useing 2 1/2in sqaure tubing to mount all this to, is there a certain distance it needs to be from the axle, or there a certain place on a fullsize chevy where it will sit flush under the bed but still clear the drive shaft when its laid out? I know thats a lot of questions but if any1 could answer just a few that would help me a TON!! thanx
s10
last post by baha +1y
