what ya think
what ya think
9
93yota
hey guys im about to do my bak bags on my truck and i was wondering if it would be a good i deal to do the behing and under bag brakets and do a two link connected to the rear bg brakets and remove the leaf springs wat do u guys
kdcgrohl's avatar
kdcgrohl
No.
kdcgrohl's avatar
kdcgrohl
two link = extreme pinion angle changes
9
93yota
y the braket isnt strong enough
kdcgrohl's avatar
kdcgrohl
no, brackets are fine, i've done link bars in those, had to cut em apart tho. you can order them unwelded if you want to use them as link points, but the two link idea is what i was saying no to.
9
93yota
cuz i wanted to do the bags in the bak and i thot about doing the two link and leave the gas tank in its place
kdcgrohl's avatar
kdcgrohl
two link bad, four link good(or as our top poster says, THREE LINK). you can leave your tank inplace, maybe raise it to avoid draggage, use an offset wishbone upper triangulated piece, and two lower bars, there you'll have a multilink with your gas tank in the stock location and no funky angles, and you can get your proper articulation. somebody else chime in here and explain why two links suck please.
9
93yota
no i wanted to do a three link with the upper wishbone but the two lower link bars i wanted to connect them to that rear bag braket
kdcgrohl's avatar
kdcgrohl
oh, well in that case, be fine, just drill the holes directly under the axle, and you'll have to order link with that width ends, or cut the brackets apart and reweld them the proper distance apart.
9
93yota
wat hole are u talking about under the axle
