resetting torsions
resetting torsions
S8
sickyota 808
what do u guys do to reset the torsions... mines hang down too low that its gettin to the point where u scrape every bump out there... I got drop a-arms but too lazy to put them on...LMK the deal with this. thanks
thepowerofcheese's avatar
thepowerofcheese
pull them out and position them up
twisted minis's avatar
twisted minis
When you pull them out to re-index them they will twist a bit, so when you put them back intop the arm, set them a bit higher than you want because they will settle a good amount when you put them back in. Then you can adjust from there at the tranny crossmember. And while you pull the torsions out you may as well put the drop arms on.
oldskewlkool
S8
sickyota 808
thanks peeps imma wrench it this weekend..
