Audio/Video \  will this sound fine?
Audio/Video Q & A
views 201
replies 0
following 1
whynotfab   +1y
Could someone more familiar with the specs let me know if this amp and sub would sound ok together? id be hooking it through an Alpine head unit.
this amp:
NEW BAZOOKA ELA100.2 2/1 CHANNEL AMPLIFIER AMP 500W 20 - 20000Hz Frequency Response Fuse: 40 Crossover Thermal, Short Circuit, Overload Protection 500w Max Power Output Power @ 4 OHM: 115 x 2 @ 4 ohm / 330 x 1 @ 4 ohm Power @ 2 OHM: 165 x 2 @ 2 ohms 101 Signal To Noise Ratio Hi-Input Level 10.5VDC - 15VDC Battery Voltage Range Bass EQ Auxiliary Fuse RCA Input Auto Turn On capability
AND THIS SUB:
Audiobahn ALUM8P 8"Product Description:
8" ALUM Series Subwoofer 80 oz. Magnet Power Handling: 350 watts R.M.S. Frequency Response: 30Hz ? 1kHz Efficiency: 91.3dB PHAT 1.75" EPDM Rubber Surround Spun Aluminum Cone 3" 4-Layer ASV Voice Coil Dual 6 Ohm 3 Ohm or 12 Ohm Operation Mounting Dimensions: Depth; 4-3/4" Hole; 7 1/4" Diameter; 8-1/2" Multi-connect Lug Lock Terminals Priced Per Subwoofer 1-year SE warranty
Subwoofer Specifications:
Subwoofer Size: 8"Impedance: 6 ohmsDual Voice Coil: YesPeak Power Handling: 700 watts approx.RMS Power Handling: 350 wattsSurround Material: EPDM RubberSealed Box Volume: 0.25 - 0.5 cubic ft.Ported Box Volume: 0.65 - 1.9 cubic ft.Sensitivity: 91.3 dBFrequency Response: 30Hz - 1kHzTop Mount Depth: 4-3/4"Cutout Diameter: 7-1/4"Warranty: 1-year SE
