Yota Lowering \  Can Do A-Arms
Can Do A-Arms
Yota Lowering Yota Suspension Yota Tech
views 1928
replies 13
following 10
bagged87toy1   +1y
Looking for some one that has ran the a-arms and if they like them. Im thinking about running them but dont know anyone that has run them any info on them will help thank you.
truck action   +1y
Will be running them, that's why I'm selling the BYC's . Steve won't install other products other than his own! So will be using his front bag brackets also. He's going install his tans mount that I already have ,also!
accrew85   +1y
ive got pics of mine on with the lower control arm brackets sectioned and new upper brackets made. i dont know how to post em but there in the garage section
kdcgrohl   +1y
here's mine. love em. worth the money, nice stuff, buy em. btw, have fun w/ the lower bushing extraction...
jeremycracker   +1y
Might some kinda dumb but when i put my ENERGY SUSPENSION LCA bushings in, the way i got mine out was simple! take a little wire brush, a torch, and water hose, blow the rubber bushing out with the torch (as much as possible), then spray it with the water hose, when the water hits that hot rubber it gets hard, then just take the wire brush and clean that shit out and your done!
twisted minis   +1y
I just got mine hot with a little blow torch, and hit the backside with a hammer a little. Then blew the flame out with the air hose, and it kept expandign and just pulled itself out.
But theres also a little metal sleeve that I think must also be removed.
guilty by design   +1y
The only thing i dont like about the cando arms is the tab they give you to weld on for the rear pivot. It goes inbetween the shaft and the bushing, that makes it to where its a single shear load on the bolt. 5 mins more of thought would have told me to put that tab after the bushing so it distributes the load to 2 points.
truck action   +1y
Can you draw that out, how you would change that support?
kdcgrohl   +1y
^thats the one thats hard. the rubber one was not bad, just drove it out with the torsion key. the metal sleeves suck. large socket and large hammer will do tho.
Wouldnt really change it, id just move it to the outside of the bushing.
