Bump steer
N
Bump steer
3tcrob
Alright is there anyway that you can adjust the bump steer on the Toyota when it is lowered? Right now my truck is just static but it is close to ride height when I bagg it maybe a inch lowered a;; said and done Has anyone put the outer tierod on top of the knuckle to make the racl a little more parallel?
Thanks
twisted minis's avatar
twisted minis
That will probably make it worse.
But its possible. You would have to have the spindle machined to put the tie rod in the other way.
I dunno about yours, but my tie rod mounts to the top of the spindle already...?
3tcrob
yeah you are right I have them reversed I work on front ends all day among other things and dint thik I need to put them on the bottom to get the rack straighter
m_i_zombie
Do you still have your steering absorber? If you replace that with a new one it will help out tremendously.
3tcrob
yeah the steering stablizer I still have it on and belive it to be good, I think you can flip them no problem the control arm shouldnt be tapered, I was think when Seth was telling Phat to swap his control arms side to side I dont think he said anything about putting the tierods on the bottom just bolt it back together they way it was taken apart, I'm going to try it tomorrow all I had time for today was to put my tires on
kdcgrohl's avatar
kdcgrohl
lmao @ ^
