Yota Lowering \  what type of link?
what type of link?
Yota Lowering Yota Suspension Yota Tech
views 1229
replies 9
lotoy86   +1y
k guys im bout to link the rear end and im stuck what type of link should i go with i want to keep my tank in the stock location whould it be better to buy a 4link from fbi and mod. it or just build one what would be cheaper? cuz im on a hella budget were talkin like 250 or less shipped if i have to let me know what you think? thanks
holcombe347   +1y
it might be cheaper to make it for the application. you'll just loose out on time. but im not 100% sure. it seems like it would be almost as much work to get a 4link and mod it as it would to just make one.
toyotaman89   +1y
^^^^^^^^ true true
lotoy86   +1y
jeff i want to do one like yours and seths so i can keep the tank in the stock location how much should i look to spend in getting the parts together?
holcombe347   +1y
well i had my buddy ken bag the truck so i paid labor for him to do it. but what i did was when i got enough money to buy all the parts i did that first then sat on them for a lil while saved up some more then had him bag it. all total in parts (and it might even be a little cheaper because baggin trucks have become a little more popular nowadays) roughly around a 800 and some change. thats everything brand new. that included compressors (150 ea.), pressure switch, relay, 6 3/8" valves (35 ea.), 2 1/2" valves (45ea) 10 switch box, 1/2" line, compression fitting everywhere (which have gone up in price since) roughly 40 per wheel in brass(that includes the fittings used at the valve assembly and bag, 2 contitech 2600 4 ply single port bags, tank, and wire. for him to install everything and build the links was like another 1000 - 1200 something like that. you could save a little cash in certain areas like if you bought some parts used (in good condition) with contitech bags, you could buy 2 ply instead of 4 plys.
then i had the front bagged a month later. but all i had to buy then was the front bags and labor.
twisted minis   +1y
$10 per bushing. You need 7 bushings, so about $80 shipped plus steel tubing, probabl $30. Total cost around $120 plus tabs which you could make pretty easily.
lotoy86   +1y
kick ass thanks seth
lotoy86   +1y
btw what type of bushing do i need? can i use a stock type bushing from the leaf springs
twisted minis   +1y
If you can find a piece of tubing the fits them properly, yes.
FBI also sells a set of 4 for $25.
lotoy86   +1y
what are you useing?
