i here you can mount a shock hoop to the frame and put the bag in between the upper controle arm and the shock hoop thats for the front for the rear its the same as a 2wd
i would also suggest mounting those loops into an engine cage to prevent them from breaking/bending off of the frame. There is alot of stress on the brackets when you mount them that way.
