Yota Lowering \  size bags?
size bags?
Yota Lowering Yota Suspension Yota Tech
views 609
replies 7
following 6
drunkdragger   +1y
What size bags should I run up front, 2500's or 2600's?
slammedcivicsi   +1y
2500 should be plenty fine, the 2600's can be a little harder to use because of their size.
guilty by design   +1y
youll prolly run 2500s. I like to cram 2600s up front because they ride better at a lower pressure, take less air to start lifting, and take less air from your tank. Its a bit more work to do tho and thats why alot of people dont run them.
skip   +1y
I have re7s up front (2600) and i love them! it was only a few extra hours of work to make them fit. I say go with re7s
92yota   +1y
you got any pics of this? and what all you did to make them fit?
twisted minis   +1y
You need to cut into the frame about an inch to make room for them. My truck rides great with them up front, and gets good lift. And I can drive about 3/4" off the ground without bottoming out.
drunkdragger   +1y
thanks for the info guys!
skip   +1y
I stuffed re7s in the front for that reason right there!
