rides
market
More
Events
Gallery
Calculators
Wiki
Store
Threads
Rides
Market
Events
Gallery
Calculators
Wiki
Store
Browse
Yota Lowering
\ Check valves...
Check valves...
Yota Lowering
Yota Suspension
Yota Tech
views 621
replies 6
following 5
zip tyd
This is going to sound retarded, but I would install these before the "fill" valve right?
m_i_zombie
You can do it that way. Putting it between the fill valve and the bag would be better.
kdcgrohl
i like em. tank empties, no worries...
zip tyd
thanks..recently I had a line break, and I lost all my air...then my truck ate the road pretty hard...that's why I'm putting them in.
truck action
If your line brakes between the bag & valve set up there's not much you can do.Check valve can't be right at the bag,or you can't dump. You can use braided lines between the bag & valves so pretty failsafe!
kdcgrohl
^or hardline it.
drupru22
Check valves can be right at the bag if you run dual port bags. You can use one port as an up and the other port as a dump that's all.
