question about wishbone setups
F
F
faded
i have noticed alot of yotas run the wish bone setups is there a reason for that? or does it just ride good? pros and cons of the setup? and from the pics i have gathered i have noticed 90% of them look like they just have the wishbone up top and two lower bars is this correct?
twisted minis's avatar
twisted minis
Yes, only one wishbone.
It is there simply because it rigidly locates the axle laterally. It doesn't make a difference in ride necessarily.
holcombe347's avatar
holcombe347
using a wishbone set up also allows you to keep your gas tank in the stock location just moved up a couple inches to keep from dragging on the ground. with a 4 link, you would have to run a fuel cell.
a triangle is the strongest shape. its the only shape that is braced at all sides at all times.
skip's avatar
skip
I would say the 2 main reasons are its simple and you dont have to relocate your tank
