Can I use these axle brackets?
bigpest88@yahoo.com's avatar
twisted customz's avatar
twisted customz
I have a quick question for you all. If I decide to run a two link with a panhard bar can I use these brackets to go on my axle if I choose to run the links starting under the frame(basically where the original leafs go but higher) to the axle?
I hope you all understand what I mean. Even if it is possible can I use the even if it says S-10?
).php
Thanks in advance.
.:ChRiZ
Twiisted CustomZ
sakustoms's avatar
sakustoms
not sure if the yota rear has that locating tab or the size. The axle tube in an s10 is 2.75" and the yota rear (far as I know) is 3" so this won't slip over the yota axle.
twisted customz
Kewl thanks. If I were to weld some brackets under my original leafspring bracket, can I use it the same way?
twisted minis's avatar
twisted minis
Cut the stock leaf spring brackets off. Its easy.
kdcgrohl's avatar
kdcgrohl
simple, and a pain to grind all that crap off. you should not affix brackets to those pads tho. new tabs directly to the axle tube would be best.
guilty by design's avatar
guilty by design
the yotas have a 3'' axle diameter in the middle and a 2.75'' axle diameter from about the frmerail out. Wierd but true.
