17's on 235/40/17
17's on 235/40/17
granth
what do i need to lay this out on a 85 yota? would spindles be a good buy, or can i do it with stock arms and spindles with some cutting and plating?
kdcgrohl's avatar
kdcgrohl
belltech is the desirable spindle manufacturer, and yes, it can be done without them, but is easier with them.
granth
is a 17x8.5 going to work? I see 8 inch wide does but I am looking at some mustang GT wheels and dont want to buy them if they wont work. I am trying to figure out what the specs on them are...
lowboytrucks
8.5 should work but it depends on the backspacing but you are goin to do some cuttin under the hood to get them to tuck
granth
cutting wheel wells and all isnt a problem im just worried about stayin in the wells, and clearing the v8 when it goes in.
smorrison1
as far as I know, you can lay an 18" wheel without needing spindles, any higher than that, and you will need them.
and your camber issues will be less with spindles as well.
granth
5-Lug 4.5" bolt circle
6.295" backspacing
45 mm offset
17" x 8" wide
these are the specs, i thought they were 8.5" wide.
moneyhungry
you should be fine. just use 4x4 fenders. i had the same size tires on a bagged 92 blazer and didn't rub when it was laid out.
granth
what will tuck on 2wd sheetmetal, i want stock metal. it seem like my grease caps stick out a long ass way too. maybe they are supposed to look like that?
