Ford Trucks \  fuel cell problem
fuel cell problem
Ford Trucks Make Specific
views 272
replies 0
following 1
bodydropped85   +1y
ok ive got a JAZ fuel cell. its a 12 gallon, plastic tank in a metal shell. ok ive got it all hooked up and moutned but my return line is seeping.i took the vent out(has the little ball in it) and drilled out the bottom so gas would flow back in the tank. the fitting from the tank to the 90 degree elbow is seeping. should i get an AN fitting ot go on there? i say this because the pump line is done the exact same way(fittings wise) and doesnt leak or anything. could since it being a brass fitting to a aluminum fitting it not seal good? ive never messed w/ army/navy fittings b4.
