Yota Lowering \  crossmember
crossmember
Yota Lowering Yota Suspension Yota Tech
views 711
replies 5
mdevaneydesign   +1y
I have an 84 toyota and i have a pulled leaf in the back with 3" blocks and when my fat friend sits in the truck it rubs the cross member under the body.
can I cut this sucker out / and or some of it, or is that bad news?
sd yota   +1y
if you have any fab skills whatsoever you can make a new, higher rise one and cut that one completely out.
either or find one on line....... i wouldnt run your truck without one there though..... its one of the main ones.
skip   +1y
if your talking about the cross member that bolts to the bottom of the frame yes you can get rid of it. but if your talking about the trans X-member then you can pick up a new one that is raised from twistedminis.com or candospecialties.com
sd yota   +1y
i think he's talking about the one right behind the cab that holds the front of the gas tank where the driveshaft tends to hit after alot of drop....
mdevaneydesign   +1y
Yeah thats the one im talking about. its right even with the back of the cab
twisted minis   +1y
Don't cut it out completely if you don't plan on replacing it. But you can notch the center. I have done this with a piece of 5" 1/4" wall tubing.
