question on link measurements
SY
sd yota
how do you guys measure for your links? gonna do 2 reverse square bars with an upper wishbone. do you just pick a mounting point on the frame where you want the bars to start and measure to the point on the axle where you will mount the other tabs? or is there a bit more science to it?
i guess, more exactly what im trying to ask is how do i measure my truck for my links? do i need to have it notched and sit the axle where i want it to ride before i measure? or can i measure for links as the truck currently sits?? or do i take measurements, notch the truck, then mount them accordingly???
twisted minis's avatar
twisted minis
I map the back half out on my steel table. Draw everything to scale, and figure out how long the links could be, and what kind of spread I want on the axle and also the frame, and where I want the IC. Then I cycle the suspension and observe it. If I like what I see, I build it.
SY
sd yota
cool...... well, what would you suggest for me since i dont really have a steel table, frame jig, etc??
i figured i could go off of someone elses similar setup if anything else.......
kdcgrohl's avatar
kdcgrohl
you could draw it on the floor with chalk if you had to.
SY
sd yota
what i need is someone thats done this before to visually show me in front of me what they did.... or how they did it....
i think i can wing it along (to a point)....... its not like i havent done it before. i can get measurements off a similar truck and have them made, then mount them to the specs provided i beleive. just didnt know if everyone had their own way of doing it or if there was a "must follow" method.
hotlavaxb2089
its mini truckin. usually most just figure it out by trial and error.
twisted minis
I told you my way of doing it. There are other ways too, but essentially the same as mine without a table. You measure the space you have to work with, figure out how much space a cross member and a tab will take, then measure from the bolt hole on that tab to the center of the axle, and that is your link length.
SY
sd yota
oooooh, ok..... yea, thats what i figured was necessary to do, just wasnt sure with what you mentioned..... it sounded like i was in over my head building one without a preassembly table of some sort.
i really do appreciate the help....... i want to do it right and hopefully right the first time. im sorry if i ask you guys previously answered questions. i just gotta ask in my formed question to get the desired answer i can understand.
twisted minis
Yeah you don't need a table, I just like doing it that way because I can visualize it better.
