Ford Trucks \  stock floored ranger 98+++++
Ford Trucks Make Specific
views 280
replies 12
following 10
laynLowEdge   +1y
just curious if you have to z the front frame if you stock floor it to the pinch
xcOpPeRx   +1y
Yeah mine is going in to the shop to be bd on 20x9
dragwithme   +1y
Originally posted by xcOpPeRx
Yeah mine is going in to the shop to be bd on 20x9 kool truck man
dburris   +1y
Bagd ranger I don't think Pascal was dissin ya. I would like to know how you have your a/c setup Pascal if you don't mind aight peace oh and Bagd ranger your truck is pimpin topless
laynLowEdge   +1y
so what did you do diffrently pascal to keep your ac because this is a daily driver and i neeeeeeeeeeeed the ac. By the way the hood scoop would of been the last resort i had
BAGD RANGER   +1y
THANX DANNY FOR THE COMMENT UR TRUX NICE AS WELL --- AND I ALSO WOULD LIKE TO THANK MARK FOR POSTING THE PICS ---- AS FOR PASCAL - YOUR COMMENTS WERE TAKEN PERSONALLY AND I BELIEVE THAT YOU R NOW BEING --- CALLED OUT --- U SAY U GOT A/C -- LETS SEE IT --- AND LIKE DRAGWITHME SAID -- ANY ONE CAN HAVE A BODYDROP WITH A/C THAT DOESNT WORK -- BY THE WAY ALL THE RANGER GUYS OUT THERE NO THAT BY LOOKING IN YOUR ENGINE COMPARTMENT THE A/C IS NO WERE TO BE FOUND ....
Sprk Sho   +1y
If you don't Z it it will lay hard in the back and not in the front the front will be like a half inch off the ground.
Dejavu   +1y
hey man im not calling you out at all.. im really sorry if you felt that way.. i am not a guy to care about fights at all.. i dont make this foruum suck.,., if you met me in person youd realize how goofy and loose i am... anyway .. since you called me on my a/c.,.... see those hoses running into the firewall? those run to the stock a/c that is under the dash.. and yes it works.. and its cold too.... i already stated earlier thats its not a hot rod unit its actually a mix of toyota and ranger stock a/c components.....ill taker a picture of it all under the dahs if thats also what you want...
bdroppeddak   +1y
oh yea, did i mention your truck is as sick as a lab rat injected with aids!!
streetsweeper1   +1y
The toyota a/c unit is a great idea for anyone is wanting their finished bodydrop to be more comfortable. Anyone who has done it right, proves they know their shit.(The fan unit is under the dash)
I stock floored a 2000 ranger and I recommend ditching the ford spindles and swapping them with toyota along with some custom control arms upper and lower, because the lower balljoint on the ford arm is flipped around the opposite way as the toy spindle. you can also swap the whole clip like that guy did. only thing is, you go from a rack and pinion to a drag link. It won't be bad it's just not the most high-tech route. I also am a big fan of hiding your motor under your hood. I have a stock floored 93 toy bodydropped 4 1/4" with a stock hood. I had to section the oil pan, shorten the oil pickup tube, drop the motor mounts, and drop down the drag link in the middle. you also should replace your stock lower control arm crossmember with a piece of thick ass steel. something like 3/8 or more depending on how much clearance you need.
