crossmember
crossmember
lilheed
im in the process of baggin my truck and i was wondering what people do with the crossmember that runs across the frame at the very back of the cab. because it looks like it is gonna hit when the truck is laid out
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
the trans member is going to hold the frame up, also the motor member will hold it from laying completely out
kdcgrohl's avatar
kdcgrohl
The one out back is usually notched on the reg cab truck(no carrier bearing) or replaced all together. Here's one we did after removing that xmember completely:
Kinda hard to see, but between the front two bed supports, there is a hoop that those curved bits of tubing go to. 1.5DOM if I remember correctly...
lilheed
thanks. does anyone else got any pics of wat they did?
I'll hopefully have more pics after this coming weekend, I pulled these off of my rebuild thread. I pie cut the transmission crossmember to raise it, I wanted it to look factory. Hope this helps.
Rob
shortyzkustomz's avatar
shortyzkustomz
I'll take some pics of mine on Tuesday when I go home
