Ford Trucks \  F150 spindles and bag questions
Ford Trucks Make Specific
views 100
replies 0
following 1
urandaman   +1y
so the spindles are now being advertised in the magazines, so they are for sure out now. so wiht the spindles that will take care of any balljoint mods i would have had to do, so now i can go about putting the bag cups and bracketry(sp) in with no probs correct? will i be able to use the factory control arms, or is buyin and modifying an aftermarket control arm easier/ a better idea?which companies control arms work the best, and do i need both upper and lower? or just the upper?and since this is my first truck that i will do this kinda suspension on, what size/model air bag should i use? its a ext cab 4.6 v8 if that makes any difference?last question from this noob heh, what else will have to be modified/altered to lay out in the front, and will i be able to lay out with the rear about 7" drop(for the time being?)
