Yota Lowering \  Sway bar
Sway bar
Yota Lowering Yota Suspension Yota Tech
views 471
replies 3
following 2
3tcrob   +1y
I have a set of can-do arms and would like to use the sway bar still going to run re6's in the front is anyone useing the stock sway bar still?? I havent tore apart my front end yet still doing the bd but it looks like all I would have to do is drill a hole in the lower arm plate and bolt it back together
Thanks
truck action   +1y
I have Cando arms also,but not a stock sway bar. Run Quickor Engineering bars,will have to make mounting tabs on lower arm, & have a new bar made(Chrome Molly Spring Steel)
Cutting the front bar up to make a pattern & test fit!
Sway bars make a big difference in handing.worth keeping !!
3tcrob   +1y
you got a linkm to it post some pics
truck action   +1y
Once I get started on that project photo's will be taken & posted!
