Yota Lowering \  1980 longbed pickup *How to Lower*
Yota Lowering Yota Suspension Yota Tech
views 749
replies 3
1980yotacox   +1y
I just bought a 1980 toyota pickup - Longbed. I want to lower the front but im not sure how. If i can i would like it to be free or a cheap mod. Any advice helps. Thanks
baha   +1y
You can get drop spindles for around $200+ that's not to bad. You can also loosen the torsion bars a tiny bit to lower it but I would just do the spindles.
twisted minis   +1y
In order to run drop spindles, you have to do some modifications to the lower arm to either flip the stock balljoint in the opposite direction, or to fit a newer balljoint. You also need to run the wheel hubs, calipers and rotors from an 84-95 Toyota. I spent about $400 doing the swap on my 80 a few years ago.
baha   +1y
^That would be the man you want to talk to!
Thanks for the info Seth.
