Baggin with Nitrogen-S10
1 following
trace@tuckintoyz.com's avatar
Lexpusher96's avatar
Lexpusher96
Hey guys, I have some questions regarding using nitrogen with bags on a late model s10. What PSI rating should I buy parts and what psi should you set the regulator to?(180psi, 300psi bags, valves, etc.) I guess everything should be 1/2" port too right? What is the parts list I will need? Bags, lines, 8 valves, nitrogen and regulator...and all brackets, wiring, etc.
How low will an S10 lay with dropped spindles, monoleaf in the rear with a step notch, and bags? I know it would depend on the wheels, but is it possible to lay frame with these components and say 17" or 18" wheels?
