Yota Lowering \  84-88 model brake master cyl. upgrade
Yota Lowering Yota Suspension Yota Tech
views 682
replies 8
following 2
nc dragger   +1y
who has upgraded to a 1" bore master cyl and could tell a difference in there braking system?
truck action   +1y
I did this upgrade @ the time I upgraded the front rotors & calipers, & change the rear to disk. So a big change was across the board!
If you are going to add rear disk , every thing I've read says to change the master. I also changed the booster too a dual diaphragm,as is much better!
nc dragger   +1y
im getting ready to change to rear disc and was wondering about the master cyl.
did you buy a master cyl with your kit or a newer model truck ? and do you have any photos of your install ? and one last question lol what booster did you use from what model?
truck action   +1y
If you e-mail me I'll send you photo's & info.
Gary/TruckAction
nc dragger   +1y
sent ya a email and a pm
truck action   +1y
Photo's & e-mail sent !
nc dragger   +1y
thank you for the info on the break etc......... question on the wiring to the master cyl
did you have to change the connector ?
truck action   +1y
Electrical--only electrical is the brake fluid level.
You just cut the wires & reconnect,always solider & shrink wrap any & all electrical work!
If I remember correctly the brake hard lines will go on with a little repositioning !
nc dragger   +1y
thanks again for all the info.
