Brake booster and master cylinder with a body drop.
lolifeyota avatar
lolifeyota
What's everyone doing with these? Just wondering what brake boosters will work for a body drop on 20s in a 94 and what to do with the clutch master cylinder? pics would help too
cable avatar
cable
73-83 toyota's are the most common with the 8in. booster that you need.the clutch master cylinder can be raised up into the cowl area,or-best thing to do IMO is to put it under the dash.
" target="_blank
there are some aftermarket under dash option as well,I have never used any of them though,I think willwood makes one too...
" target="_blank
" target="_blank
this thread is a good read...
" target="_blank
bigruff avatar
bigruff
I installed the one from performance online in my truck. The one for both the brake booster and master and the clutch master. It comes just the bracket and two new pedal arms. u connect ur clutch master to it and I bought a new 7 inch booster and corvette master cylinder. works great. I boddied mine to doors and wanted a smooth firewall and really had no where to put the booster and master anyways. I got the booster and master off ebay for 100 bucks brand new.
lolifeyota avatar
lolifeyota
So pretty much as long as i get matching booster and master cylinder, anything will work?
been reading into the geo metro boosters, just don't know what year.
cable avatar
cable
I hear the metro boosters are a bit weak...
n2bnlow avatar
n2bnlow
Get a 1983 Toyota 4X4 truck brake booster. They are about 1.5" smaller in diameter, but you still get the same amount of vacuum boost. I've heard that the Geo booster will give you a real stiff brake pedal. I'm running the 83 4X4 booster, and everything feels normal.
