Clutch Master Clylinder
lscivic
I have a 93' Yota that I am laying out on 20's... I already recessed the clylinder an inch but it wasn't enough. I heard of people using an older clutch master clylinder but I haven't heard if it works.. Does it? Can I put an 89' cluch master on there and be smaller and still work????
Steve
///RA SoCal
lscivic
Alright, well I figured it out. I used an 88' Master Clylinder and it worked. It took a little bit of "lovin'" to get it to work but it did. Had to shave the piston rod down a little. But the master cylinder is back another inch so I have 2 inches tucked in.. Works so far...
Steve
///RA SoCal
oldsklminitrk
Do tell how this was done mine is digging into my tire and Ive been working on a way to recess it and I only got 17s
xmdragonass's avatar
xmdragonass
use a clutch cylinder from an 80s 4x4 toyota... they are way smaller and shorter ! thats what i put on mine...
Y
yotalac
sweet i was going to ask the same thing...
i ordered some BAD wheels and i was affraid of how i was going to tuck them
dmlynlow
your gettin rid of your importish wheels?
cable's avatar
cable
I recessed my clutch master cylinder straight back 4 inches and didn't really have any problems
guilty by design's avatar
guilty by design
Im diging this up because before too long ill be doing this. Ive seen pics of Seths setup but does anyone else have any?
holcombe347's avatar
holcombe347
yeah the clutch master cylinder out of my 88 is pretty small compared to the new bodystyles. i can take a pic if you want, but because these particular ones are smaller, it wouldnt take much to recess and it be out of your way. with my truck laid out on my 17's with 40 series tires, they dont even come close to touching the mastersylinder. hell i even had enough space to put a wheel well in there and clear everything with flying colors(im not bodydropped but when i tubbed my wheel wells i jacked the tire up as high as it would go without picking up the truck)....with your 18's and my year cylinder, recessed a lil bit, you should be fine.
twisted minis's avatar
twisted minis
Your truck also isnt bodydropped. I think they look like poo recessed, which is why I put mine under the dash. You can move it up though, above the pinch. I think that looks okay. But you need a removeable cowl to get to it. Mine is part of the body, unlike yours.
