Yota 2.4L 22-RE I4 \  Funny idle prob
Funny idle prob
views 1151
replies 7
following 5
yotalac   +1y
i have a 92 toyota. for some reason it sounds like my idle is off.
i can be sitting still, and the idle will rise, then drop....over and over.
it will not stop.
is there somthing to fix this , can i do it or is it somthing i will have to get get fixed...??
also....my exauhst is trashed...no cat(crushed that a couple of moths ago)
and muffler has broken its weld...could this be the prob??? no back pressure???
truck action   +1y
Bad thermostat, engine not getting to running tem., so won't come out of cold start mode. Engine as to get to 190 degrees!
3in2out   +1y
Could have to do with you crushed cat if its that bad, if your exhaust is that beat up it could be related to a couple things. Do you have a check engine light on or anything?
truck action   +1y
I had the extact same thing going on,it burned out the converter,& woundn't pass smog. With a brand new LC engine ! Rpm's would go up & down only from one range. That was the cold start injector putting fuel into the engine because the tem was staying low. Just pull the theromstat & see that it's not stuck open!
yotalac   +1y
cool beans
i'll try that...as far as check engine light on....yes i do....thats because i had the cat removed cus it was melting the asfualt and it smelled like shit.....but since then the exhaust sits low...so i fixed it...i flatened it out...and now the muffler is broken off....lol...i cant win!!!!!
oh well...i'll try the thermo see if it fixes it...
johnny5   +1y
and check your o2 sensor mine went out and did the same thing
dmlynlow   +1y
good luck brian
yotalac   +1y
gassi-ass....you guys have been a big help......
