Has anyone ever done or know if its possible to put big disc brakes up front on the 94-01 rams.I want to know before I order arms from BYC when he finishes the proto-types.
Jance Customs
Do you think you could use a big brake kit from the 02-06 Rams on our 94-01's? I have belltech drop spindles instead of stock so maybe they would work? I know you can bolt on the new 20's from Dodge on our rams would the brakes be as easy to use too?
Low_SST
Originally posted by 98ramm
its ssbs who carries brakes for the 94-01 ram.But its only slotted rotors (same size as factory) with a brake caliper from a 1 ton ram pickup. I was thinkin if theirs a spindle that I can use thats similar to the ram which would allow 14in rotors (if so I might need different balljoints)or if there is a way to modify my stock spindles. Part of the spindle over hangs the rotor which wouldn't allow for a larger rotor.
i think the big brake kits require some cutting of the spindle
