Yota 2.4L 22-RE I4 \  We Need A How to on Cleaning the 22r(carb) engine
views 3212
replies 13
following 7
phatboislim   +1y
whats the steps on cleaning a carb engine, i can do a fuel injected no problem but im afraid of messing up something w/ the carb'd engine. anyone give any wisdom???
baha   +1y
are you talking about taking it all apart? I agree it would be a very useful tech article
phatboislim   +1y
that too but im talking about cleaning the engine bay area. mine right now is nasty and ive tried to do it before, but its like no matter how much i try not to get water in/around da carb it always seems to try to choke out
twisted minis   +1y
Clean your motor with carb cleaner. And anything painted, like the valve cover, use oven cleaner. It cleans pretty well, and doesn't screw up the paint. Just don't get the carb or the rotor cap wet and you'll be good.
phatboislim   +1y
dont think carb cleaner will work on my greasy engine. its like alota caked on old oil/grease. just tired of looking at a nasty engine. if it was fuel injected no problem woulda stayed clean
twisted minis   +1y
So do what I did. Drive it to a pressure washing station (do it legally, lol) and cover your motor in the degreaser they have, then turn the pressure washer on. The majority of that crap will come off. Then use carb and oven cleaner for the rest.
phatboislim   +1y
if i do that then the carb will get filled with water...*if only i had a 22re (at least)*
2pumpchump   +1y
Don't aim the water directly at the carb. I use to wash my engine and bay every time I washed my truck and I never got water in the carb. If you got the factory air cleaner, def. don't worry about getting water in the carb. Also, I used Castrol Super Clean, and a pressure washer. That stuff works better than simple green and engine bright combined.
phatboislim   +1y
i duno man i tried cleaning before and it would act like its about to choke out. ima try it one more time i guess, b/c my engine bay is a mess and it needs a serious cleaning
twisted minis   +1y
If you get the cap wet your motor won't run well either. I took my truck down the the pressure washer and soaked the motor, had no problems with it.
