any one ever had this problem
projectneverdone
hey i have a 92 toyota just had a fuel cell put in few other things but nothign to the motor. I was driving hte other day check engine line starts blinkin then the truck starts boggin down wheni it the gas like tis going to stall. It did it liek 3 times hasnt done it again untill a little while ago any ideas?
loluxtrux's avatar
loluxtrux
My engine bogged down really bad a couple of times when I had water in the air flow meter plug.
truck action's avatar
truck action
Pull the pump out of the tank & check the connections. If the hose that connects between the pump & metal tube came lose or isn't tight you won't get enough pressure!
1rawtoy's avatar
1rawtoy
mine did that a few times...found out it was the fuel pump relay going bad...so I took it out of the system and wired it to the ignition...
projectneverdone
thanks guys im gonna look into it.
