wheels rubbin bad..
wheels rubbin bad..
DropTopLowLife
ok i got some 18's.. by like 8.. and when i bust a U-turn, my wheels dig the shit out of my frame, and firewall when i bounce doing my turn.. like wtf, everything is relocated, no fenderwells, yet i still rub... iuno how to keep myself from not grindin my wheels against the frame.. spacers to push it out some maybe? any ideas hit me back.
mtm's avatar
mtm
ehhh well from that pic it looks like if you get spacers your going to lose tucking abilities...is the damage noticeable on the frame? Like can you see on the frame where it rubs because if not, it might be rubbing on your tie rod ends inside the wheel...
TEEBAGGINNN's avatar
TEEBAGGINNN
Do not turn the wheel as much. Try having 18x 9.5 inch vette wheels.
twankydeuce
can you notch the side of the frame?...that might be a bad idea tho, never seen that done before, only the lca's
aftermathdragr
put steering stops on your lower control arms
V
vio0633
I have shocks on my truck and bagged and I rub as well a little. After a while you get used to how wide the most you can turn without rubbing. U might as well kiss u truns goodby.
LT
laynlow toy
i have relocated shocks that were there when i got the truck i have mad rub when i turn sharp. the shocks are welded to the frame right behind the control arm so when i turn left the left tire is rubbing ,if the shocks are in front of the control arm is there less rub?
sr98219's avatar
sr98219
I have 20x9.5" on my s-10 and they rub but I just learned how far I could turn my steering wheel w/out rubbing.
no1lowr's avatar
no1lowr
Edited: 9/3/2005 8:05:07 PM by NO1LOWR
i think its hard for some folks to grasp that when you roll a bagged, lowered, lifted ride, things change, and instead of being able to find some solution to the wheels rubbing, you just have to make the adjustment of making 3 point turns, im just glad i can still make u turns laying door, fuck yea, save air. woot
DropTopLowLife
thanks for the feedback, i figured not to much i could do. i def cant tuck with spacers.. i tried it the other day. but yeah to matt (ss ten) its pretty noticable on the inside of the frame, my driver wheel just digs the fuck outa my frame, u cant see it on the wheels.. dont really care, just seein what ideas yall had. thanks
