Wheel Questions \  22x9 on back of an s10
Wheel Questions Q & A
views 310
replies 19
following 10
Drag-N-Low   +1y
with 5.5bs what size tire should I run?????? and do i neeeed to worry about anything?
Drag-N-Low   +1y
bump
idrgbdy   +1y
i'm wondering the same thing too! probably like 255/30/22.
jdhidlebaugh   +1y
I think 255 is a little too small.. I could be wrong. Id go with a 275/35 or 275/30/22 if I were you.
Drag-N-Low   +1y
Edited: 8/2/2005 8:50:27 AM by Drag-N-Low
yeah im thinkin 275
yumuggn   +1y
I dont believe they make a 275-30-22 I can get you a set of 285-30-22s They would be 28.73 inches tall. I also can get the 255-30-22 But i think they would be stretched to thin on that wheel
Tennessee Wheel and Tire
tnwheelandtire.com
Thanks Cameron 931-636-1425
twankydeuce   +1y
someone on here is running a 295/25 22 on the rear of a s10
tofnlows10   +1y
jason is on his noma....check lo-n-po
Drag-N-Low   +1y
well I dont need that smallof a tire, its for the back, ill probably run a 285/30 then.
thanks guys
idrgbdy   +1y
does anything need to be done to make these fit? like can you just bolt these on a bodydropped dime as long as you get 5.5" of bs? of course the bed would need to be cut, but any other modifications?
with a 3.5" b/d, would a 285/30/22 stick up past the bed rails?
