I am looking for a lower ball joint to fit a S-10 spindle. But it needs to be the "bolt in" type. I don't care if it is for another application. Thanks for your help.
eks10BDRG-N
you mean bolt in like the upper ball joints do with the 4 bolts?
SlowDime
Yeah, same idea. Just need the tapered stud to fit lower part of the spindle
SlowDime
Does anybody have any suggestions. One of my buddies told me that Barnyard Customs uses a bolt in lower ball joint on their arms. Does anybody know if this is true. I've tried calling them several times, with no answer.
DawgsledMazda
well leave a message and ill call you back. its unreal, i get 10 calls while im busy and nobody leaves a message.
I use the stock style balljoint on S-10 arms, but I also use the S-10 balljoint on Toyota lowers, and the toyota one bolts in, try that or ill try it at the shop today and let you know. speedwaymotors.com sells a screw in balljoint and sleeve that fits the S-10 spindle, not sure if that will help you or not.
