a buddy of mine has got a 95 honda civic and i hooked up the dog leg valves today but when we dump the opposite front corner it brings the other front corner down a little and the same back corner drops a little the wheel is sucking up but is not coming off of the ground is there something im missing or do we need do something different on the suspension
THEshortBUS
Edited: 8/7/2005 4:38:43 PM by THEshortBUS
This is a sick dogleg... lol just playin dude
JUG
might not have enough psi to hold the car up try turnin the pressure up if you can
luv2sprk
yeah, u need like almost 200 psi to pull a huge dog leg.
Duckn
you don't need a lot of pressure really... juat make sure the air is fully aired up when you do it.... i'd recommend check valves on all four corners... mine pulls a pretty good dog leg and really all i did was add the check valves so that the air wouldn't leak back in to the tank
bagged4doorintegra
yea u prolly need more air man i had to run about 200psi when i had that on my car it would dogleg a lil with like 160 in it but i raised the pressure up and i could dogleg about 13 or 14 inchs easy but try putting more air to it
later
