Duallie Tires
lodually@yahoo.com's avatar
Duallie Tires
nrskinny's avatar
nrskinny
Im just wondering what size tires most people use on duallies with 16" tires. Im trying to get the truck to lay on the stock size tires so I dont have any problems towing. But the rear fenders arent wide enough. Looking for some new ideas.
lower
narrow the rearend or extend the fenders
baggeddogs's avatar
baggeddogs
a 205X60X16 or a 225X60X15...
nrskinny's avatar
nrskinny
I would love to widden the fenders. I only need about 1/4" on each side. If I did have them widdened I would parobably extend them about 1/2" each for good measure. The only problem is I dont know anyone around this sorry area that could do it and do it right.
dragndodge's avatar
dragndodge
I am runnign 215/60/16 on mine...
outlawcrewcab's avatar
outlawcrewcab
i ran 225-60-16's you just trim the lip off the fender and you will gain about .5"
yumuggn's avatar
yumuggn
you can run a rear end out of a older chevy bread truck.
periportfd
If it isn't body dropped just trim the fender lip like Joe said. With the stock tire it will probably rub the inside still but it won't go through. If you want something smaller, run the Michelin LX4 235 60 16. It is a little bigger than others but has a weight capacity close to 2000 lbs.
