94 Dakota Rear Question
Sitnlow@verizon.net's avatar
sitnlow4life's avatar
sitnlow4life
The rear went in my 94 Dakota I heard from a few people this is a common problem on this truck.Anyway It is Std. Cab 2wd 4cyl 5spd it has a 10 bolt 6 lug rear.I was in the local salvage yard today a nd found a 92 Dakota Ext. Cab 2wd 8cyl 10 bolt 6 lug rear.Will this work for my truck will I run into any issues?Thanks
9
94dakota
The gear ratio is diffrent. I don't think you would have enough motor for the gears. I'm about get another dak for parts where you from I might be able to sell you the rear end out of it
sitnlow4life
Sounds good
Where are you located?
Im in PA.
Its hard to find parts for this truck around here.
