Audio/Video \  HOW CAN I FIX THIS ?
Audio/Video Q & A
views 176
replies 9
following 8
97LONOMA   +1y
how the hell can i fix this it looks so ughly ?
tooleyhc   +1y
You can try a little clear suction cups like one that goes on the inside of windows of cars to hold those "Baby on board" signs. Just lick, stick and pull! Hope it works. Thats always a bummer to look at that. L8
mobileheath   +1y
vacuum cleaner....use the hose part....it'll suck it right out
bagged300mondubs   +1y
you can also use a needle or safety pin, a little hole wont hurt it at all!
fatheadjames   +1y
If none of those work the only other way is to pull it off and push it out and silcone or epoxy it back on.
97LONOMA   +1y
man i tried everything and nothing thats some hardass plastic and the worst part is that its the sub thas in the midle off my seats it sucks
nrskinny   +1y
If there is a hole in the middle of the magnet on the back. Carefully push something through the vent hole and push it back out.
97LONOMA   +1y
nope theres a screen on the back
nrskinny   +1y
You could pull the screen off. It wont hurt the sub. You may even be able to reatach it. Just becareful running something throught there, and dont use metal.
incognito 1   +1y
TAKE A HOT GLUE GUN AND TAKE A WIRE BEND A 90 DEGREE TURN IN IT AND GLUE IT TO THE CENTER THEN PULL AFTER UR DONE U SHOULD BE ABLE TO PICK THE GLUE SPOT OFF
