Dog Legging with parker valves
DRJEKLL
I currently have a EAI kit installed in my 95 accord, due to the design of the parker valves I cant pull a dog leg.
Is there anyway I can modify the valve to pull a dogleg, or do I need to replace the valves?
I wish to retain the parker valves in aid of ride comfort....
Any help tips would be great
N
neurotic
Well since you are using parkers and the way they are designed by one vavle used for lettign air in and one vavle for lettign air out. You basically have to run another set to that cylinder and have them hooked up so that when the one set is letting the air out the other is pushing air and vice versa. You ride is going to be different also. I have rode in many of cars that had not been able to pull a wheel up on cylinders and then they do it and it rides stiffer.
Ih8bmps's avatar
Ih8bmps
Not sure if your talking about dog pissing or sucking up a wheel? Cause dog pissing shouldn't have anything to do with the valve,its how your set up is.You would dump the front corner and if you have enuff lift it should come off the ground.If your running cans you have to use the valves in a push pull style set up off the can so you can suck the wheel up.
s10
last post by baha +1y
