Yota 2.4L 22-RE I4 \  Help with clutch problems?
views 900
replies 3
baggedtoy92   +1y
Allright, I got a 93 yota today. When the truck is running you can put it in every gear without pressing the clutch in. The truck will not move in any gear and doesn't even try to move. Would those be symptoms of just needing a new clutch or is something else wrong??? Thanks
mexicant   +1y
try replacing the master cylinder and the slave cylinder , then bleed it out real good ,
toyotaman89   +1y
sounds like the clutch is totally gone....lay under the truck on the pass side, look at the clutch slave and have sommmeone push in the clutch pedal...if the slave pushes out and moves the clutch fork, the only thing i could think of is the clutch disk has blown up, or the trans is totally shot. probably the disk though... good luck!!
3tcrob   +1y
Sound like the Clutch assy. If the slave cyl or the Clutch master was bad it would still go into gear
