small weld on bushings?
doofie
Where can I get small weld on bushing for control arms (upper) Suicidedoors only has 2" od. I thought they had 1.5"
BAGD RANGER's avatar
BAGD RANGER
ASK JASON AT SD TO FAB SOMETHING UP -- IF NOT TRY PETE & JAKES -- BOTH HAVE VERY GOOD PRODUCTS --- MINE ARE SUICIDEDOOR BUSHINGS 2 INCH THOUGH !!!
dssur's avatar
dssur
Speedway has some
They dont come with the outer sleeve though, but its easy, you get some 1 1/8" ID .250 wall tubing and cut it to exactly 1.5" lengths (I paid a shop with a good band saw so they'd all be the same). We've made more than a few 4 links using those bushings. Jasons are nice too, but are slightly overkill. The speedway bush4es are made to do rear suspension on old doorslammers with big blocks, they will do minis just fine.
They also sell a front suspension bushing that uses the same ID pipe but is only 1 inch wide, so if you are doing custom lower control arms.
dssur's avatar
dssur
I'm a dumbass, you said uppers didnt you.
Thats okay, the info is still good. Best of all, they only cost 25 bucks for a set of eight split poly bushes and inner sleeves.
Here is a direct link as my apology for not reading your whole post lol.
N
Nic
Yep Speedway bushings work great.
dssur's avatar
dssur
NIC!! where you been fackface? We still camping in September?
DawgsledMazda's avatar
DawgsledMazda
I sell the sets, outer sleeve, innser sleeve and 2 energy suspension poly bushings for 10 bucks. the tubing is 1&3/4" od DOM tube with a 1/4" wall. these are for 4 links and we use them for upper control arms.
s10
last post by baha +1y
