rides
market
More
Events
Gallery
Calculators
Wiki
Store
Threads
Rides
Market
Events
Gallery
Calculators
Wiki
Store
Browse
Toyota Trucks
\ wheel offset
wheel offset
Toyota Trucks
Make Specific
views 170
replies 7
following 5
92yota
will a 50mm offset on 18x8s tuck? and does the bigger the number of offset mean the wheels stick out farther or is it the other way around?
slamrbri
The bigger the number in mm the less they will stick out or the closer they will be to the center of the truck, and yes 50mm will tuck just fine. Just curious, which wheels are you talkin' about?
92yota
i was looking at the stock rx-8 wheels
92yota
since these are 8 inches wide with a 50mm offset will they be tucked in too far and cause any problems?
the501clique
depending on how you lay it may be too far in my 18x8.5s have a 40mm and are about 3/4 of an inch from hittin the brake booster
92yota
last question...what is the difference in +50mm offset and just 50mm offset?
PimpinMidgets
the only wheels that should be run on toyotas are the stock steel wheels...toyotas are gay
SeveredBody
THERE IS JUST + OR - OFFSET'S
