wish bone link
longnlow84@suddenlink.net's avatar
wish bone link
justin skaggs's avatar
justin skaggs
I'm doing 2x2 square bars from suicide w/ bags mounted on them. Simple front back no side to side. would i benefit more frome a triangulated or does it matter. i was looking at their new universal wishbone link.
truckguy2000
are you trying to do a 4 link or 3 link if so bags on bars won't work they twist the bars unless you can mount them directly over the bar like on a 5 link or 6 link if you don't want side to side do a 2 link with a track bar with heim joints on the track bar that the best 2 link setup
LP
Lil Pink DS
2 link will give u more lift. And the farther towards the front of the truck u mount your bags, the higher you'll be able to go. We also mounted shocks on our 2 link bars at an angle which improved the ride greatly and we can go from almost stock height to laying frame.
Pneufab
why would a 2 link give you any more lift than a 3 or four bar setup with the bag set in the same place on the lower bar?
it doesn't
t
bdroppeddak's avatar
bdroppeddak
you'll need 7 more bars on that wishbone to get the lift of a 2 link.
LP
Lil Pink DS
I'm sorry. I meant the 2 link versus the 4 link because the 4 link limits how far the suspension will travel. And most 4 links are done with round bars whereas all of the 2 links I have seen were with square bars which u can easily mount the bag on without the bag being centered on the bar.
bdroppeddak
just kiddin, a wishbone is cool, just make sure if you put the bag s on the bars they are in the middle to prevent premature bushing wear.
s10
last post by baha +1y
