Chevy/GMC Trucks \  Removing and Painting a 90 Silvy Dash
views 141
replies 8
following 7
ShakinPlates   +1y
Im considering smoothing the entire dash and painting it. A few questions... 1: How hard and long does it take to remove the dash and 2: will a sand down to smooth then primer then sand then shoot do the trick? Can I do the same thing for all of my plastic trim? If you know where I cann find any sites that I can get help on this that would be great.
aftermathdragr   +1y
it took me 4 hours to get my dash out, they have a few bolts in wierd ass places. One thing u can do is scuff the dash, then spray it with a high build primer and sand that out but it will take a few coats to get it perfectly smooth. Hope that helps
aftermathdragr   +1y
BTW yea u can do thats for all of the platic trim.
Lil Pink DS   +1y
Yeah that's all we did with my civic is sand smooth, spray bondo, 300 grit sand, and paint. Should work with amy hard plastic parts. Not good for vinyl or airbag covers.
joshdupre   +1y
depending on the color plastic and the color paint on priming. Really all you have to do is spray this paint adhesive then shoot the paint. The adhesive helps bond the paint to the plastic so it does flack and chip easy. Of course sand it good to get it smooth.
ShakinPlates   +1y
Im doing black paint on black plastic. What is this special adhesive called?
IheartmySST   +1y
its just plastic adhesion promoter
dragginburban   +1y
hey bro im a painter in houston i do interiors all the time their is this stuff callrd zcrome u can bu it at auto zone it 95 dollars put one good coat let it tack up then lay two more coats wet sand 400 base and clear and your done using high build primer three heavy coats wets sand 400 another two coats wets sand base and clear their are the two different was that work good you pic later bro
ShakinPlates   +1y
Hey guys thanx for your help... I got alot off just to find that the main part looks like its pop rivited on? Is this so? I dont really feel like goin to all the trouble to get those out.
